F350 GETTING TO HOT FOR ME
Discussion in 'Engine & Performance' started by SPORTSMAN, Mar 31, 2021.
  1. SPORTSMAN
    SPORTSMAN Junior Member
    FAYETTEVILLE NC
    94 F350 4x4 Carb engine 5.8 351w---lifted 37x12.5x16.5 tires---410 gears---c6 trans 3 speed auto----is going up to around 220 pulling boat at 50 or over-----2000 procraft 20 ft 200 hp mercury----not pulling boat its not over heating. It has got a all aluminum radiator 3 core in it-----because of lift kit had to put a 2 fan made with shroud electric cooling for the radiator---has a 180 thermostat----fans are working fine and can feel real hot air being pulled through the radiator---here's the questions I have----should I convert fans to push instead of pull because of thickness of radiator and condenser together----should I put flex fan back on it to help keep all that hot air out of bay when and if I change fans to push instead of pull---should I go another way like electric racing cooling water pump---Been advised different ways as in changing gears in rear and front axles could do the trick but that's high as I have priced it .Every things new on this motor as well as the motor--and yes I know I should be pulling boat yet till I get more miles on it less than 500 on it now---just trying to see if there's another way I can go that might help so I can keep temp down and rpm down cause if change gears it will go up.
    SaveShare
    Reply Quote
  2. gruesomesurfer
    gruesomesurfer Full Access Member
    Las Vegas, Nevada
    Any update on this?
