Fabtech Question
drdfblackm
Member
Flagstaff, AZ
Can you use 17" stock wheels on a F150 4x4 with a 6" Fabtech lift or is the offset wrong? Can the stock wheels be spaced out to work or would it require too much spacing?
you should be ok might rub on steering knuckle depending on what size tire you run
