Heres the order you'd do this ... 1st pull his lift off inspecting it all as you do it 2nd pull your stock parts off if all his parts look ok 3rd put the lift on your truck 4th get the hell out of there asap
pretty much worth going to a pull-a-part and buying a cheap stock setup and doing it that way Sent from my DROID X2 using Tapatalk
don't you have to cut part of the crossmember off to install a bracket lift like procomp? or is that just 04+ cause in that case he would need to get that part welded back on his frame and whoever got the kit would have to cut it off their truck
