Friction modifier
Discussion in 'Engine & Performance' started by TxFx04, Jun 16, 2012.
  1. TxFx04
    so take the diff cover off and let that shat drain? or take the fill plug out. how hard is the front diff to do?
  2. str8t six
    str8t six never enough
    Back in VA
    make sure you can get the top plug out first before you take off the rear diff cover.
    take rear diff cover off, let it drain. wipe inside of diff with rag to get old stuff out. clean the cover from old gasket material. apply the new gasket material. wait like 5 mins for it to harden some. install diff cover. wait till the gasket dries. put in new fluid.
    for the front all you have to do is drain and refill. since it does have a front drain hole.
  3. TxFx04
    Gotcha! one write up i saw said to take off the rear ABS sensor that mounts on the diff to add the friction modifier. true?
  4. str8t six
    Back in VA
    no. i dont see why you would need to do that. just put in the thru the fill hole.
  5. Brandon
    Brandon Member
    Michigan
    My rear end shudders sometimes when taking off/turning from a stop. Did yours stop when you drained it and added the FM to it? I plan on doing mine within the next few weeks hopefully. Did you use the FM from ford or stuff from the auto store?
  6. 05F150XLT
    05F150XLT Member
    Lakeland, GA (Moody AFB)
    Mine used to shudder, and it does now again, at about 75k I drained the rear end to alleviate it, but I forgot the FM, so it only took a couple thousand miles for the shudder to come back. That is on my list of things to do, so hopefully I can cure it for a little while longer this time.
