front drive shaft U joints.
Discussion in 'General Discussions' started by Pity7700, Jan 14, 2014.
  1. Pity7700
    i think i might have a big C clamp, no vice at the house though. its at my grandpas barn.
  2. Pity7700
    borrowed allys jeep to go get a ball joint press, no luck so far. 3 seconds away from getting out the grinder to cut the joint off.
  3. Roush PSD Interceptor
    Grinder off ya did.
  4. Pity7700
    I should have just got the grinder right away, would have saved time. ahh well.
    im going to have to finish in the am, on of the needle bearings fell on the face of the cap and got cracked in half. something always breaks, all I can do is laugh!
    my buddy will give me a new joint and let me return the other. tried to salvage a bearing from the old joint but they were shorter and fatter.
  5. Pity7700
    Ended up changing both, having an issue with getting the shaft balanced. Any tips? I've got a bit of a wobble.
    EDIT: found that the collar on the front slip yoke has been pushed off a little bit, have a feeling this is the issue. not sure how this happened, don't remember dropping or hitting that side while changing the joints. able to smack it back in place with a mallet?
  6. Pity7700
    well got it taken care of.
    sadly, U joints were not the problem. clunk is still there lol.
    time to check motor mounts like Joe suggest a week ago.
  7. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    Hopefully it's nothing serious. Last time I had a clunk in 4wd I ended up needing a new Tcase.
    Sent from my HTC One using Tapatalk
  8. Pity7700
    the clunk is heard in both 2 and 4wd. just sounds like something is loose.
  9. AK SNO RIDER
    Soldotna, Alaska
    When does it do it?
  10. str8t six
    str8t six never enough
    Back in VA
    that sucks chris!
    can you get a video of the sound?
