Front driver side vibration
Discussion in 'General Discussions' started by Ricky Williams, Apr 10, 2025.
  1. Ricky Williams
    Ricky Williams Junior Member
    Louisiana
    2013 F150 XLT 4x4.
    I’m getting a vibration on the front driver side. Not like a bad tire or anything. It actually sounds like a mud grip tire on down the highway. It doesn’t matter if I am accelerating or not.
    As I’m slowing down, I can hear it slowing down also.
    I installed a new CV shaft.
    I put a new bearing assembly on there, an upper control arm and Also installed a new IWE actuator. I have new brakes and rotors also.
    The IWE system is working properly.
    The shaft isn’t turning when it’s not supposed to. And turning when it is.
    To make sure it wasn’t a tire, I’ve had three different tires in that same spot trying to figure this out.
    The only thing I haven’t changed is the lower control arm.
    Nothing has changed. It keeps getting worse.
    Im completely stumped!
    I hope somebody has some answers!
