Fuel gauge not working
Discussion in 'General Discussions' started by cowboy, Jun 4, 2012.
  1. cowboy
    So I went to fill up the truck this morning, and when I was done, I started the truck up and the fuel gauge didn't move. By the time I got to work it has moved up to a half a tank.
    The float that controls the gauge is part of the fuel pump right? I can't replace that separately?
  2. VanoFord
    from what i remember in my Haynes, you are correct... hopefully its just stuck and will get back right again soon.
  3. W.Hirsch
    W.Hirsch Yippie-Ki-Yay....
    Millington, TN
    I would put a few more tanks through it before replacing. The 250 did the same thing one day. Took it 24 hours to get back to the full line. But the next tank it was fine. Hasn't done it since.
  4. cowboy
    cool will do
  5. Bee89
    Bee89 Super Moderator
    Miami, Florida
    I read a sulfur build up could cause an inaccurate reading as well.
  6. ak_cowboy
    Theres one other thing that causes that. if you leave the key on while fueling up it doesn't reset to where it should be. Next time you fuel up make sure your keys are out of the ignition and see if it happens again
  7. cowboy
    I did leave the key's in the ignition.
  8. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    or a loose ground
  9. UtahFord
    Ya my 06 did the same thing if the let's were in it
    sent from my badass F-350
