Gears? What ratio is best?
Discussion in 'Engine & Performance' started by BlackThundah, May 29, 2012.
  1. BlackThundah
    Pretty much a mix of both. I drive on the high almost anytime i want to get somewhere with speeds over 60. But i dont drive for a long distance normally about 30-35 min at the most. Other times im driving just locally. And i do both about just as much. AS for what transmission i have no idea. I'll have to go look in the owners manual here in a minute.
  2. str8t six
    str8t six never enough
    Back in VA
    is it a standard or auto?
  3. TFIDDLE
    i have as much power as i can for the mods i have because my tune is finally near spot on. I might could turn them if I had efans underdrives and longtubes.
  4. BlackThundah
    Oh my bad, auto.
    I just dont under stand if your tires are only 2 inches all around bigger than mine and you have a performance tuner with a v8 might be the 4.6 but you still got the extra 2 cylinders and you cant light em up. I guess the tires are just so much heavier maybe.
    Rotating mass takes a lot more power to spin than stationary weight though. Usually figure that 1lb of spinning weight is equal to about 7lbs of dead weight.
    Get the 4.56s, you won't be sorry.
  6. TFIDDLE
    ive also got a crew cab (heavier), over 150lbs of tools in toolbox, 35inch spare, 120pluslb sub and subbox, and usually have 2 or more people riding with me so i have a loooooooooot more weight. Bigun still swears he had no problem turning his 37's on blowcaine with stock gears so you might be alright with 4.56s
  7. str8t six
    Back in VA
    may want to consider the 4.88's then. you will turn about 2K rpms at 60MPH
  8. TFIDDLE
    im turning 2k at 60 with 4.56's
  9. str8t six
    Back in VA
    thats interesting :hmm:
  10. TFIDDLE
    well the calculators say im not so i guess im just near it and I hadn been in my truck in 2days so it may be 1800-2000 but i cuda swore it was right at 2k
