Good Crossdrilled or Slotted Rotors???
Discussion in 'Wheels & Tires' started by Darth Bama, Jan 25, 2011.
  1. J.Wal
    :chewie: Sweet, you wont have any problems with them!
  2. VanoFord
    Drilled AND Slotted. If you can find one w/ both, that is the best. I have a set of D & S Rotors that I got off of eBay (some guy in Canada) and have never had a problem. I run the truck hard. Usually hit 100mph once a week. I don't do a ton of towing, but when I do, i am loaded out. I do a lot of payload carrying (if thats how you wanna define crap in the bed), upwards of 1500lbs no problem. In all 3 instances, I have never had an issue. I also run Hawk Pads (pads make a HUGE difference). Hope this helps.
  3. Darth Bama
    I've been looking at Hawk and EBC pads. Thanks for the info Vano.:waytogo:
  4. tater
    tater I WANT IT ALL
    Holland, MI
    had ebc pads before on a diffrent truck and where were the best pads i bought
  5. 01f1502wd
    any of yall think about getting bigger calipers? or just run the stockers?
  6. J.Wal
    It was too expensive for me to justify bigger Caliphers when I don't tow often or really have a need for it. When I go to running 38s I may look into it depending on how much stoping distance I loose.
  7. Darth Bama
    Bigger calipers are nice, but unless you're doing some really high performance driving there's not much need for them. If I were building a Lightning or a Mustang making tons of power I'd look into a Brembo kit or something equal, but with everyday driving I personally don't need them and would rather spend the extra money on something else.
  8. 01f1502wd
    I see. well maybe ill just stick with stockers then :jester: my fronts are getting low, so ill save up now then change them in a month or so.
  9. Darth Bama
    ^^Yeah man, just throw you some quality pads on there and some good rotors and the average driver will be fine. Like I said, unless you plan on racing an Autocross race or joining the SCCA there's no need for ultra high performance calipers and rotors.
  10. 01f1502wd
    I was thinking about racing Ken block in my truck.....bad idea?:banana-mario:
