got a 2018 F150 super crew Lariat (need help)
Discussion in '13th Generation F-Series : 2015 - Present' started by mhbell, Jun 13, 2024.
  1. mhbell
    mhbell Junior Member
    Ogden Utah
    it has the push to start button. I only have 1 key fob so need a ket fob, a owners manual and need a key code for the door key pad. I looked for the code at the passenger footwell fuse door, but no tag or code. is there another place to look? Any help appreciated.
    Mel
  2. 4ctNduction
    T-E-X-A-S
    i found the code for my doors in the glove box...in the owners manual.. with the second key. haha so thats no help to you. i looked on google real quick and there are a bunch of places selling the fobs for that truck relatively cheap. 44 to 70 bucks and there are videos showing yu ohow to program it. I watched those videos and programmed a couple of them for my old truck
  3. mhbell
    Ogden Utah
    I found the code in the passenger footwell. You have to remove the door to the fuse block, the footwell trim and a 1/4th hex head screw that hold the fuse block to the wall. You can pull the fuse block away from the wall just enough to get a mirror in the space to read the code on the back of the fuse block. I used a flashlight and 2 mirrors to read the code which the sticker says (key Code). I used the second mirror to see what the first mirror said with the light shining on the first mirror. the code worked for my door key pad. there are a couple of videos showing how to do it.
    Mel
