Hard time starting help
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by joeygr8gt, Feb 10, 2014.
  1. joeygr8gt
    joeygr8gt Full Access Member
    Lately the truck has been havig a hard time starting. It crank a lot then two seconds later it starts. It's not the battery bc it has a fast normal crab the engine just dose t fire right away. Let it run two min turn it off then start and it's fine. It can't be bc it's to cold bc it's 32 and it was fine when it was 15 out. I'm stumped.
  2. iowaredneck
    Fuel pump or water in gas???
  3. joeygr8gt
    Truck runs fine and normal. I was thinking starter. When it runs for few min everyjing fine
  4. iowaredneck
    Yeah but your not getting gas right away which means fuel. Just a thought. You could always try and run some heet through it and see if that helps.
  5. iowaredneck
    Always could have starter tested to be safe
  6. ak_cowboy
    I would check the fuel pump.
    Next time you go out to start it (cold) Turn key on, count to 5, key off. Key on, count to 5. Engine start.
    That should prime the fuel lines if there is a problem there. Otherwise, get the starter checked
  7. joeygr8gt
    fuel pump was changed if I'm not mistaken 10k miles ago
    ill check the starter
  8. joeygr8gt
    I did the key thing and truck started normal. Turned off let sit few min started right away
  9. iowaredneck
    Hmm that still makes me think fuel pump.
  10. joeygr8gt
    How would I test to deff make sure it's the fuel pump
