Having some Issues..
Discussion in 'General Discussions' started by TLSF150, Jun 13, 2012.
  1. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    So I think this all has to do with my HIDs..
    #1 After installing the HIDs my SES light came on and wont go off.. Ive tried reading the DTC codes with my SCT but it says no codes found.. I even tried clearing the codes anyway but it still wont go off..
    #2 A couple days ago I jumped someone off when I hooked the jumper cables up my headlights came on by thereself even though the switch was off.. even after I turned my truck off they stayed on so I tried flipping the switch back and forth but that didnt help.. finally i flipped the highs on and the lights went off.. Now every once in awhile when I start the truck up the heads come on or when I turn my lights off the heads stay on and the only way I can get them off is to turn the truck of and flip the highs on and then off..
    WTF is going on??
    Oh and on a unrelated note... I think my AC compressor is about to lock up... FML...
  2. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    Something is wired wrong IMO
  3. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    Might sound stupid but do you have all the correct parts with everything wired correctly? There should be a relay with a ground and a wire to the battery (with a fuse). Other two wires from the relay go to the ballasts. I'm not too electrically inclined but it almost sounds like the relay could be acting up.
  4. TxFx04
    What the hell did you do to DDM to piss them off??
  5. iowaredneck
    i'd check for a short
  6. cowboy
    ^agreed
  7. VanoFord
    definitely sounds like a short. and i feel ya bout the AC. I dont have mine working now cuz i need to replace an o-ring/ wont hold a charge, keeps blowing off. :facepalm:
    good luck on the HIDs.
  8. 01f1502wd
    ya probably a short. my controller is shot and I think the bulbs are gettin old (ive had em for almost 4yrs) so im thinkin about just goin back to regular halogens since my LED fogs are super F*ing bright anyways I dont need foglights lol
  9. TLSF150
    Stockbridge, Ga
    Damn well ill have to check this weekend to see what's goin on.. you guys think a short would make the SES light stay on with no codes???
    Sent from my HTC EVO LTE using Tapatalk 2
