Hbs sucks!!!!!
Discussion in 'General Truck Discussion for all Generations' started by webb, Jul 10, 2012.
  1. Big'un
    Well new strut assemblys it is
    Whats the dif in the 2 i posted?
  2. TxFx04
    who knows when in doubt get th better one. or tell him to get bilsteins
  3. iowaredneck
    New struts for sure
    sent from the lake
  4. ak_cowboy
    Get rid of the HBS and just get some Bilstein 5100s. New shocks and a lift all at the same time
  5. yz85rider2002
    The Quick Strut is supposidely a better riding assembly versus the Econo-matic
  6. Big'un
    The bilsteins only lift 2" max it says
  7. Eric of Memphis
    munford tn
    smh........... if it only measures 1 in and wtfe you wont get that out of it maybe an inch a rough country level measures 2.25 in and you get 1 and like a 1/2 or some **** like that .... but fk it lets just throw parts at stuff and not fix nothing .... :facepalm: now granted the struts are prolly wore out but the spring is what gives you your ride height....... but honestly i think it needs new front and rear diffs and the trans might be shot
  8. VanoFord
    ^^^ its the struts and coils. 138K is about 65k more than they should have. most struts are only good for 60k, and the coils are maybe good for 80. another way to test the struts: stand on the bumper, get the truck bouncing pretty good then jump off. the truck should bounce 1 more time after you get off then stop. if it bounces a couple times til it finally stops, its the strut assembly 100%.
    hell, i've got 140k on my truck and i just started on my 3rd set of struts (factory got bout 60k, Rancho got 70k).
  9. Predatory Instincts
    Burger King's bathroom
    Incorrect information. Strut spacer levelling kits measure well under the resulting lift. You get as much lift from the geometry change in the front end as you do the spacer.
    If a Rough Country measures 2.25" it either doesn't mount the same way or it gives you about 4" of lift.
  10. bktabolts
    bktabolts Full Access Member
    Uranis
    Depends on how much money etc you want to put into it. If you do Bilsteins, you should also get new springs to go with. If you go the rancho way, you won't get the full lift you want but comes with springs. But I believe you can get the rancho's with out the spring. Correct me if I'm wrong. Like some peeps already said, sounds like the springs are what bad! But what do I know! LOL
