Ultra Mako 6 Simple, smooth design = less time cleaning them. Thats what I look for. Dont get any thing like whats on mine in the sig. You'll spend an hour on just the wheels. All I can say is Im glad there black lol. I detailed them when I put em on and that was that. Now its just pressure wash and go.
Ok, so now that I have decided on the Mako's, what offset should I get? I'm thinking 25 should be the right one... But I don't understand offsets very good-like still. But I have heard the stock rims are +44 offset, so 25 will stick out a little further if I'm correct here...
I don't quite understand this... I thought getting closer to the - offsets would cause the tire to stick out further?
yes negative(-) offset pushes your tires out positive(+) pulls them in. -25 is only going to push them out 1"
Ok. That makes sense then. But i don't want to have to worry about Rubbing. I'll probably go tops of 33.5" tall tires, depends on what I find. And I have a level. So If I go with the +10 offset I shouldn't have to worry about rubbing?
The place (website) I'm looking at only has them in a +25 and a +10 offset. So I'm kind of limited to one of those choices.
