I need a diogram for the headlight switch in a 03 screw with auto lights. i want to find the HOT wire for your interior lights on the little turn dial switch. (the one to change how bright your dash lights are) I'm put in LED bed lights and i want to hook them up so what when i turn that switch on to have my interior lights on my bed lights come on. Thank you for your help.
the switch that controls the brightness has 2 wires. Hook the bed lights up to it. if it stays on while changing the brightness its the other wire.
Just go off the cargo lights in the third brake light. They come on when u turn the interior lights on
Smaller grey plug C244 W/B Fog lamps on indicator Grey Plug C245 DB/W Power (hot in park or head) W/R Lamps on output to GEM BK/PK Ignition (hot on acc) BR Exterior lamps output T/W Power (hot at all times) O/LG Dome lamp switch Black Plug C246 BK Ground Y Fog lamp switch LB/BK Radio illumination DB/O Power (hot at all times) R/Y Headlamps output LB/R Switch illumination circuit
