Help!
Discussion in 'General Discussions' started by joh408, Jun 23, 2012.
  1. joh408
    joh408 Full Access Member
    Highlands Ranch, CO
    The oil gauge dropped to below low. And when I restarted the truck it went back to above halfway
  2. cowboy
    Usually that happens with a blockage. When was the last oil change?
  3. Roush PSD Interceptor
    sounds more like an electrical issue to me.
  4. joh408
    Highlands Ranch, CO
    Last oil change was about 3k or so ago. I was gonna change it next weekend. Think I should change it this weekend?
  5. str8t six
    str8t six never enough
    Back in VA
    Any updates?
  6. joh408
    Highlands Ranch, CO
    Been busy studying for tests but I am going in today to get the codes read. I drove it for a bit with no problems and then it felt like something was resisting when I was braking. It was weird because it went away in the next 15 miles or so. I replaced the front brakes probably 15k ago and the rears about 1k ago. I'm not good with the technical stuff really so hopefully the codes will tell me something. I checked out the serpentine belt, no slack or anything from what I could see. Undid the grounds to see if anything could be causing a bad ground. Nothing. Terminals were tight and had solid contact
