Help
Discussion in 'General Discussions' started by Shane09, Nov 22, 2012.
  1. ak_cowboy
    The shuddering while passing could be the spark plugs, especially if they're still stock at 155k.
    The jolting is defintly the torque converter. Take it to a dealer, drive it with them and show them exactly what's happening. It should start around 40mph after it's shifted into o/d and you're trying to speed up a little or go up a hill.
    Then get back to us and tell me how much it'll be to fix it :jester: mine is doing the same thing.
  2. Tradesman
    Tradesman Full Access Member
    Vancouver, BC
    Have you checked your transmission fluid condition and level?
  3. Shane09
    Shane09 Full Access Member
    Olive Branch, MS
    going to have it all checked here tomorrow cause i got up under the truck and noticed that my oil pan is leaking now...
  4. Tradesman
    Vancouver, BC
    Let's tackle one issue at a time. I can tell you that from my knowledge there have been a number of 5.4 owners who had oil pan leaks. I know there was a write up on another forum where removal of the crossmember was involved.
    Remember that when you're checking your fluid it has to hot, which means driving for quite some time. And be sure to check it on a level surface.
  5. Shane09
    Olive Branch, MS
    yeah i know.. im taking it to a shop to have them replace the gasket if it is what is bad. i work at a car parts store so i can get the parts cheap. i really dont have the time to do it myself.
  6. Shane09
    Olive Branch, MS
    Well I changed the plugs the other day and it did seam like they were the orginal ones..all my problems have disappeared atleast for now so I'm hoping thats all it was
  7. cowboy
    sounds good
