hey guys, airbag light flashes and then stays on constantly.
Discussion in 'General Discussions' started by Pity7700, Feb 15, 2012.
  1. Pity7700
    Anyone have a clue. ive been doing some searching and reading about it. read taht it could be the impact sensor. i ihavent gone out to check yet, also read it could be a fuse. figured id go check the everything that runs off that fuse.
    has anyone had this problem before? its kinda odd.
    thanks guys.
  2. Pity7700
    im thinking its the clock spring in the steering wheel. my horn doesnt work either.
    when i turn the steering wheel i can hear something clicking. The airbag light flashes 3 times, pauses and flashes 2 more. i read that a flashing light and a non working horn are usually the symptoms of a broken clock spring but i cannot find the flash sequence anywhere.
    can anyone verify this?
    if anyone has replaced their clock spring before how is the job?
  3. Eric of Memphis
    munford tn
    your right code is for the clock spring not a bad job but here are directions
    T
    1: Make sure your wheels are pointing straight ahead
    2: Disconnect battery
    3: Remove the four screws that hold on air bag from the backside of the steering wheel
    4: Disconnect and remove the airbag
    5: Disconnect the connections going to the horn and cruise control buttons
    6: Remove the bolt that holds on the steering wheel and use a puller to get it off
    7: Unscrew the tilt lever from the column
    8: Remove the three screws that hold on the steering column cover and remove the lower portion
    9: Remove the ignition switch by inserting your key and turning it to the on position and inserting the end of a paper clip in the access hole in the bottom of the switch housing to depress the pin that holds the switch in
    10: Remove the top half off the steering column cover
    11: Remove the lower dash panel that is directly below the steering column by removing the two screws on the lower side and gently pulling toward the drivers seat to release the pins that just snap in on the top side of the panel
    12: Remove the clock spring assembly from the column and disconnect all connections
    13: Put in new clock spring and reconnect then put everything back in reverse order
  4. Pity7700
    awesome. thanks man. now do i have to wait a certain amount of time after i disconnect the battery before i mess with the air bag?
  5. Eric of Memphis
    munford tn
    well i have always waited at least 15 min i do touch the pos and neg together after they are removed from the battery ...
  6. Pity7700
    ok i will try that
    i appreciate the run through. just gotta find some time to take care of this, as for now i just hope i dont get in an accident.
  7. jmurph
    jmurph Full Access Member
    Michigan
    seems like youve been having nothing but problems lately chris.
  8. Pity7700
    :jester::flipthebird: its all good. i got everything under control.
  9. jmurph
    Michigan
    haha, thats good.
  10. Pity7700
    job finished. a bit of a pain in the ass though. i will do a full write up with loads of pictures in a day or two and post it up.
    the only snag i ran into was getting the proper steering wheel puller. i rented one from advance auto parts but it wouldnt work. had to go get one from my mechanic.
    Airbag light is gone, horn works and cruise control. problem solved!
