I was trying to install them and the dang directions suck. There is a hi, lo, and ground wire comin from the relay but they are not labeled. I switched them around a couple times but still no switching. Sent from my SCH-I500 using Tapatalk
good luck. i bought mine from ebay and was supposed to have hi and lo and i never got them to work. they are bright enough on low so i just left them like that
Dangt. Lol did you just switch the wires around alot? Also it wont burn anything up if I switch wires around alot will it? Sent from my SCH-I500 using Tapatalk
im not sure maybe someone else will answer for you i followed the directions and never got mine to work. even when i turned my fogs on it showed to be on bright. so who knows.
I dont know which wire on the new relay is high beam, low beam, or ground. They are not labeled. Can I reverse the order until I figure it out? Sent from my SCH-I500 using Tapatalk
PnP ftl. Ebay PnP ftmfl I love seeing these threads, if you can't get them to work, they belong nowhere near your vehicle and that's their way of telling you that.
Okay im not gettin projectors so forget it. I like these blinding things and am askin for an answer. Not an opinion. Sent from my SCH-I500 using Tapatalk
