High idle and stuck in first gear, automatic transmission
Hoserdave
Junior Member
Denver
This has been intermitted problem. I changed transmission fluid. the truck will stay in first gear unless I shift it down in two second, automatic transmission. If I shift it into neutral, the idle goes up to about 2000 RPM. no engine lights on the dash? should I change or clean the IAC part. or and change the transmission solenoid? both of these happen at the same time. Help someone please
