agjake11
Suck my tailpipe
Ok so i switched all my dash lights to white LEDs to get a blue illumination thanks to raptor's how-to but one part was left out. The headlight switch is more of a pain to convert but is still very doable.
this is in no way a perfect method as ford has many switch configurations and there are at least two ive tried and been successful with. i am not a professional only a DIYer
on the 97-98
the switch body comes has clips around the edges and if you lift them up with a screw driver it comes apart very easy. i dont have a pic of the outside but heres what it looks like taken apart.
the arrow points to the culprit. if you turn the post to the right it comes out the back.
the leads for the stock bulb are wrapped around the base like shown
you can undo these and pull the bulb out. then with the Blue LED i got from radio shack (rated at 3.7V and 20mA) run the leads down the post just like the stock one. the long lead should be the positive but you can check this to make sure. you will need to add a resistor to the bulb so it wont blow the LED. i used a 680ohm 1/2 watt resistor from radio shack. then i wrapped the negative lead around the post like the factory bulb. then i wrapped the lead from the resistor around the other post like factory. then i trimmed the resistor lead to make the connection smaller. then solder the positive lead form the LED to the lead from the resistor.
bend them into a shape where they dont touch and will fit in the whole in the switch body. then you can re-install the bulb. it make take a little convincing to get it to turn but it will fit. test the light to see if its in the correct direction. the bulb is a diode so it will only work one direction. if it doesnt come on turn the bulb back out then turn the bulb 180 deg and try it again. should look like this.
then re-install the cover and your good. the cover may need to be slightly forced on since the new LED is slightly bigger than the stock bulb but it will work.
finished pic
99-03
technically to do this mod you do have to "break" your switch the face does come off by pulling it and popping off the little tabs holding it on. it can be glued back on when your done.
the red arrow shows the face that must be removed. the green arrow are the clips that hold the inside in.
after the face is off it will look like
to remove the inside you must turn the dial all the way down. then you pull on the dial portion and release the clips shown by the green arrows above.
the insides will be removed as two pieces
then take the piece shown
there are four clips shown below that release the dial
after the dial is off you have access to the solder points for the stock bulb. with your soldering iron you can heat up the solder and pull the stock bulb out. then you must do the same configuration with the bulb as the 97-98 with the resistor and place the negative lead in the lower location the stock one was in and the positive in the upper. (if you are holding the piece with the stock bulb at the top as shown in pics) then solder the leads to keep them in place.
it will look similar to this. (im going to clean this one up to make it work better but i left the leads long while it tried the process.)
then just replace the part you modified then the dial portion and glue the face back on and your good to go. to get the best light output make sure the bulb is as close as possible to the factory spot.
hope this helps
any questions feel free to ask
on the 97-98
finished pic
99-03
hope this helps
