Auburnfan400
Longbed done right!
Ok, for those of yall like me, i ended up with the ugly "bar style" stock grille. And after about 5 years of lookin at the old, faided plastic, i decided to paint her black to tie in with the truck. So here's what you do, its very easy. First, you got 1 of 2 choices. Either tape around the grille, and paint it on, or take a little more time, and actually remove the grille from the truck. Bigun took his off i believe, and i left mine on.
Next, take some very fine grit sandpaper, or even an s.o.s. pad or one of those abrasive kitchen scrubbers and just go all over the grille. Basically roughing it up, giving the paint something to stick too.
After that, make sure its clean, no dirt, or bugs still on it, and spray on your desired color. I used Krylon matte black paint, but any spray thats made for plastic will work. Spray on as many even coats as you feel is necessary.
Let it sit up to an hour, till its dry, peel back the tape and there ya go! did mine in May and still looks perfect, if you want a shiny look, go over it with gloss but its really up to personal preference
