HOW TO: Push Button Start
Discussion in 'Tech Info' started by lil_dq, Dec 13, 2011.
  1. 97madness
    The switch on your dash, if that was hidden a bit better. It wouldnt matter if its keyless or not. PLus you should still be able to have the keyless entry or aftermarket/OEM alarm correct?
  2. 1998f150wes
    1998f150wes CLASS OF 2013
    Guthrie, OK
    what if i put in a carbed motor and still wanted to use the key would i hook up a test light and see which ones are on at ACC-OFF-ON-RUN and hook coil up to ON and starter to RUN
  3. lil_dq
    lil_dq Full Access Member
    Union, MO
    Yep. I still use my keyless entry, I had the PATS system disabled, and again this mod is NOT for everyone. I just like to be different! LMAO oh and full coverage is nice to have as well, just in case.
  4. lil_dq
    Union, MO
    If you check out the pic in the 1st post that will tell you which are which. Oh and I'll be honest, I am not a fan of carbed motors. Not sure how you would go about that to be honest.
    Nice. I did the pushbutton start, but left the need for the key still there.
  6. 1998f150wes
    Guthrie, OK
    oh thats real easy im not gonna go about doing it til my 4.6 gives up then i got a mild build 302 with mild cam and P/P Head,intake,exhaust with shorties and it cost me about half the 4.6.
    also is RUN=ON and START= engauge starter
  7. lil_dq
    Union, MO
    Yes you are correct on that.
  8. 2thousand5four
    2thousand5four Full Access Member
    Virginia
    I'm gonna revive this thread cause I love the idea. So when I got my truck custom tuned I had MPT disabled the PATS system then I installed a remote start. Will my remote start system still work if I did this? Right now when I remote start the truck I have to get In and turn the key to the run position before I can go do anything or it will shut off. I installed the remote start myself so I know all the wiring so if I have to rewire it it's not a big deal. Thanks
    Sent from my SM-G920V using Tapatalk
  9. ak_cowboy
    If you follow the steps where he removed the ignition tumbler, you shouldn't need the key anymore, since the truck while view it as being in "RUN" all the time.
  10. 2thousand5four
    Virginia
    That's what I thought. So I should just be able to flip the switch and go then correct?
