I lied, one last question
Discussion in 'Wheels & Tires' started by Auburnfan400, Jun 30, 2011.
  1. Auburnfan400
    Hartselle, Alabama
    I put off getting a re-alignment mainly for the $$$ but i also had this question. Would the re-alignment differ any with new tires? Or...i guess the easiest way to ask, do i need to wait for the new tires to get put on, then get it aligned, or can i just go ahead and do it before? i don't know if a bigger tire will affect it
  2. The Batman
    The Batman Rest In Piece
    cold hill ky
    wait till after the tires dood
  3. 01f1502wd
    meh some ppl will say you dont need tires to get it aligned..others will say you do. I think as long as you get it aligned now and get the new tires rotated and balanced your good.
  4. Predatory Instincts
    Burger King's bathroom
    The alignment machine mounts to your wheels. New tires should make zero difference.
  5. The Batman
    cold hill ky
    well...ima mechanic and i haTE to do an alighnment then have them got new tires and complain about pull or whatever....its better to get the tires first so it can be aligned with the tires your going to run.....kinda like aa ustom thing,....if you change tires the camber and toe can be different depending on the tires and sizes....
  6. Darth Bama
    I'd personally wait.
  7. Auburnfan400
    Hartselle, Alabama
    Well looks like the alignment will be after regardless, they just called saying the tires are in so assuming i can get done with everything i got today before they close i'll have the new tires on and alignment before work tomorrow if they got the time
  8. iowaredneck
    sweet dood, getting it all done at the same time is the best way
  9. Auburnfan400
    Hartselle, Alabama
    Well awesome, while i was at the tire shop, i got a buddy that works there to look over the front end and see if anything needs tweeked or replaced. And sure enough, my ball joints need replaced bad. Bad enough that i don't even feel comfortable driving the truck to work and back.
  10. The Batman
    cold hill ky
    see....you should listen to the batman....he knows stuff....
