I need 1.5" more of clearance
Discussion in 'Lifted' started by Grumpie, Dec 5, 2016.
  1. Grumpie
    Grumpie Junior Member
    Texas
    1480949929838-149239521.jpg My 07 f150 4×4 is at stock height. I absolutely need another 1.5 - 2" more of clearance.
    I'm leaning towards 33" tires with taller coils up front to level and have additional clearance.
    The tires on it now are 31.5.
    Thx
    Get some Bilstein 5100s all around and an Add a Leaf for the rear. That will raise you 2" all around and have room for 35s
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  3. Grumpie
    Texas
    Sounds good and all but wouldn't a gearing change be required to accommodate the 35s
  4. ak_cowboy
    Depends on what gears you have. If they are 3.73s and you don't do much towing you'll be fine. If only 3.55s and/or towing/hauling a lot, 4.10s would be a worthwhile upgrade.
  5. Grumpie
    Texas
    3.55s is what's on the truck. Any towing I do will be in 4wd
  6. Grumpie
    Texas
  7. Grumpie
    Texas
    I've been reading about the hell bent leveling kit for $70. I'm surprised to see that there are no bad reviews thus far.
    What are your thoughts on the kit. A 2" clearance up front would do wonders.
    I'm rubbing on the rocks coming back down the mountain from our cabin.
  8. Grumpie
    Texas
    I would think 33s would be enough but when loaded down with lumber I might end up with the same problem all over again. So maybe 35s are the way to go. I did read that after the hell bent leveling kit was is installed 35s could be used without any issues
  9. Grumpie
    Texas
    What do you think of the proximo Xtreme and or the gladiator tires?
  10. Grumpie
    Texas
    That was supposed to say procomp.
