im almost positive this time that water is getting inside the door and running down the inside and coming out of the holes in the bottom, when i opened the door earlier it all ran to one end and poured out, so the only way for it to get in is between the window and rubber or between the mirror and door
That's false..if there is a gap anywhere in the silicone that seals the windshield it'll run right in. Pop ur cowl panel off and check the seal
already have, windshield doesn't leak, just put in new door seals and siliconed the rear window, i've been chasing this leak for almost a year now and have pinpointed it to certain areas, water pours out of the holes in the bottom of the door when you open it and one of the factory holes lines up perfectly with the wet spot on the carpet, might also explain why the bottom of the door is also rotted out
i chased a leak in my 07 for 3 months, finally gave up and called a guy called the water doctor. he found the leak in 2 1/2 hrs. it was the bottom windshield clip on the drivers side.
ok i definitely found it now, its leaking in between the window and the outer seal just like i thougt some time to drop another $50 on the damn'd ole truck
