I want a project... Here are my thoughts and questions.
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by Bdons-SD, Sep 12, 2012.
  1. TFIDDLE
    if you want welding work, get a ranger and take the bed off and start your welding with a prerunner style rear.
  2. 2011F150
    2011F150 Full Access Member
    Venus,TX
    Yeah i hear there, i wouldn't get into all the body chop and such unless there was cause or reason or i rolled it or something and it were just cheaper to go that direction. this is my old wheeler here from when i was 17-20
  3. Bdons-SD
    Awesome! Yeah, I try to avoid fender chopping ha ha, bu l do what needs to be done.
  4. TxFx04
    or if you wana weld you could get a ranger and do a SAS and weld on some leaf mounts and such
  5. 01f1502wd
    ^ yeah B, if you get a TTB ranger let me know, I have some threads for you, or if you convert it to SFA I also have some threads you need to check out.
    I want your drum set!!!!!!!!! Ill give you 200 bucks and an antenna I still owe you :hidesbehindsofa:
  6. joh408
    joh408 Full Access Member
    Highlands Ranch, CO
    Lot of good SAS builds on pirate4x4 and explorerforum for both Ranger and Explorer. Seems pretty easy to swap a HP44 in there if you know how to weld and such
  7. 01f1502wd
  8. joh408
    Highlands Ranch, CO
  9. 01f1502wd
  10. AKBray907
    there a reason youve ruled out a fullsize bronco? i loved my bronco to death. such a great truck and parts are cheap, easy to lift. unbreakable.
    i think a 7.3 bronco build would be the cats meow
