I'm back!! ..and i gots questions....
Discussion in 'General Discussions' started by 3.8 GTeater, Apr 1, 2013.
  1. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    I really don't have an input on anything, just wanted to say welcome back since it has been a long time since you have been on here
  2. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    Broken stud on the exhaust manifold, cam phaser, loud injectors, etc
    Rough idling (ignition), bad plugs, plug boots, or cops
    Fuel filter or air filter could be full of dirt. To many things could go or be wrong
  3. Roush PSD Interceptor
    Welcome back Heather.
    Good to hear from ya again.
    Maybe the CEL (check engine light) will come
    on throwing a code that can help narrow
    down the possibilities of what is wrong on the truck.
  4. cowboy
    sounds like the guys gave you a whole laundry list to check.
  5. Pity7700
    welcome back!
  6. iowaredneck
    Yes we did lol.
    Congrats on the job and boyfriend heather
    sent from area 51
  7. 4ctNduction
    T-E-X-A-S
    youre in SA too? yall should come out to some of the meets or the racetrack when we go.
  8. 3.8 GTeater
    3.8 GTeater Full Access Member
    Rio Medina, Texas
    Lol whoa , good to know you guys missed me! :) I did use 5w-30 instead of 20 and like I said I added Lucas to it too, I thought that might have helped quiet the tick but not so much. I'm thinking a plug getting ready to go bad, or maybe a wire arching whenever he slows down? For whatever reason maybe they touch, causes an arch and then it miss fires, when he revs it up, the motion pulls the wires apart and it stops? For some reason I think I remember hearing that your spark plug wires should never touch. Irk, its been a while since I've worked on a vehicle or done any research so I'm feeling a little rusty.
    I'm ashamed to say, but I've never changed a brake pad before, and today I'm gonna tackle the Volvo by myself. It seems simple from what I've read but is there anything I should know, tips or tricks? It's sounding pretty bad, and the rotor on drivers side is pretty torn up, that's will have to be replaced but at a later date, kinda broke at the moment lol
    Sent from my EVO using Tapatalk 2
  9. cowboy
    use the pad to push the cylinder back into the base. Don't let the caliper hang by the brake line
  10. 97madness
    My truck would idle super bad at a stop until i replaced the failing o2 sensor
