Im on the prowl for wheels and tires!!!
Discussion in 'F-250 and F-350 General Tech and Info' started by Bdons-SD, Aug 20, 2011.
  1. Bdons-SD
    So I was doing a walk around on my truck and i noticed my driverside rear tire has worn significantly more than the other side. The tires have some uneven wear on them already from being in the front and the guy before me having a bad alignment, just a little uneven wear on the inside. My fronts are still a good 40% as well as the one rear, and the other one is about 25%.
    Im prowling craigslist for a decent used wheel and tire package in the 35 inch tire area. Im budgeting about 600 to 700.
    I figured I could get 1 tire to replace the worn one, but then Im looking at a set of 3 tires by next year and thats just a pain in the ass, so Im opting to buy a newsed set and sell mine off while theyre still worth something. Hoping to get $300 to $350 for mine. figure thats 100 bucks a wheel and tire, plus a free wheel with a worn tire. I was going to paint them black and I still may do that if I find just a set of tires, but its easier just to bolt them up instead of taking them to be mounted.
    what are yalls thoughts if any?
  2. Bdons-SD
  3. Big'un
    Claws r good on the road, I've had 3 sets, but them r bald. I like them rims though
  4. joh408
    joh408 Full Access Member
    Highlands Ranch, CO
    I've heard they wear kinda fast on pavement like <30k but good for mud
  5. Big'un
    They are as good as the 2000 toyos I had
  6. Bdons-SD
    He said 70% but I guess I'll never know until I actually look at them.
  7. TxFx04
    check em out they look decent. but brand new claws have alot of tread those pics look like 30-40% tread. idk it may just be a bad pic
  8. Bdons-SD
  9. Bdons-SD
    Id rather have bfgs if the tread is good.
  10. dieselchick
    Tennessee
    I had the mickeys on my first truck and had to replace them after a year, they wore bad. I like the toyo open countrys...that's what I had on my F250 before I lifted it. I went to the Nitto mud grapplers after I lifted it because they look more aggressive ..but you should check out the toyo open countrys.
