lift kits
Discussion in 'Lifted' started by dlilly88, Mar 19, 2013.
  1. dlilly88
    dlilly88 Junior Member
    Monticello Illinois
    id like to run some 35s i ended up getting a skyjacker lift kit given to me its a 3" has front struts and rear leafs.... curious if anyone knows if i have to take my level kit on the front to use another lift in the front
    As long as your not adding to the level kit you should be fine.
    Do you have a link to which kit you got?
    sent from my igloo
  3. 01f1502wd
  4. ak_cowboy
    Do you have some pics of your truck?
    With a 2.5" Level you can fit 35s, same with a 4" or 6" lift. 37s can sometimes fit with a 6" lift and the right tire/offset. Most guys do a 6" lift + 3" BL for 37s. You'll need 4.56 gears if you go over 35s also.
  5. dlilly88
    Monticello Illinois
    the kit i have is the f430stk from skyjacker came with new shocks that go inside my springs and i am assuming im missing a lower strut seat.. im calling skyjacker tomorrow to see if i can get another one... my buddy and i had one side apart and aparantly the factory coil seat wont work like skyjacker said it would i hope they will hook me up with another matching the one i already have
