Loss of power
Manillagorilla
Junior Member
Texas
Ok so 2010 f350 v10 cruising right down the highway at 80mph for about 45 min then falls on its face can’t go over 30 lightly floating the petal barely like 1/8” pedal movement any more back on its face. Codes thrown were for fuel rail pressure sensor and random cylinder misfire. Recent new filter since then still the same issue. Unplugged the rail sensor. Can get up to 60-70 gently on the pedal till it randomly face down till about 30mpg or so if I shut it off then restart lasts about 15 min as long as no up hill or back on it face. Codes thrown for fuel rail being in plugged but no more misfire but not much throttle power since the rail sensor not sending proper mixture to the injectors. Been this way for 4 days now had to think it’s the fuel pump in my past experience they usually don’t give that kinda warning they just stop. Not sure if has that teabag filter in the pump could be clogged ? Or the rail sesor faulty any thoughts ?
Runs better with fuel pressure disconnected bul limited power. Plugging it back in leads to misfire codes
2010 F350 SD V10 6.8L 246k miles
Please excuse any typos, or grammar mistakes, Sent from my iPhone using Tapatalk
Just to update it was the fuel pump and the fuel pressure control module replaced both g2g
