Master Cylinder Rebuild Kit/Manual to Power Brake Conv.
Discussion in 'Exterior' started by davbell22602, Oct 5, 2011.
  1. davbell22602
    Bunker Hill, WV
    Where do I get a master cylinder rebuild kit that has the outside seals for 67F100 2wd 4 wheel drum brakes. What do I have to do to convert from manual to power brakes with a 4 wheel drum system? If have to buy a new master cylinder I'll see about converting from manual to power brakes.
  2. Big'un
    just convert it man , it will make it alot better stoppin and easy to fix also
  3. davbell22602
    Bunker Hill, WV
    I can get Bendix combo kit that comes with both the master cylinder and power booster from napa for $165 100% new.
    Ia A-1 Cardone parts any good?
  4. supercrewzn
    Cardone is decent stuff
  5. davbell22602
    Bunker Hill, WV
    Thanks for the info. I thought it was another junk brand in brake parts like duralast. I had nothing but trouble out duralast brake parts. I'm currently using Raybestos on my daily driver and some parts for the 67 F100 I'm restoring.
  6. supercrewzn
    I've used cardone stuff before and had no problems with it
  7. Big Daddy
    Big Daddy Roll Tide
    Fayetteville Ga
    Just go all out and get the bimbo 4 disk conversion kit with 14" rotors and the 16 piston calipers
  8. davbell22602
    Bunker Hill, WV
    Is the power brake booster bracket different on the 67 F100 from the 68-72 F100? Its the bracket that mounts on the firewall under the hood not brake pedal bracket.
  9. davbell22602
    Bunker Hill, WV
    Nobody?
  10. Darth Bama
    Not sure about the Bimbo kit, but those Brembo brakes are bad ass. :jester:
