Me and my moms ride (somewhat pic heavy)
Discussion in 'General Discussions' started by 07Fx2, Jul 16, 2011.
  1. iFX4
    iFX4 Chief
    Florida
    I was about to say....my 04 is a 1 piece.
  2. Darth Bama
    It's not bad or good, it's just a pain in the ass when you lower one. I haven't heard any complaints about 2 piece driveshafts so I assume they work fine. :peace:
  3. supercrewzn
    2 piece is better when lowering. It is alot easier to get the pinion angle correct
  4. Darth Bama
    My 1pc. has never been an issue. No carrier bearings, no shims, no vibration.
  5. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    Deric from ground force said the vibration people are having with the other kits is because they have no carrier bearing relocator and no transmission spacer. He said the gf kits come with that. I made sure to ask all the Nessasary ? :)
  6. supercrewzn
    With those, you won't have an issue except maybe clearance.
  7. 07Fx2
    Oklahoma
    Im doing a 2/5 drop and he said it'll perfectly level my truck. clearance issues won't be a problem cause it's not really that low and no rubbing with the 305/40/r22s. The ground force kit don't need cam bolts either cause it's all factory specs.
  8. Darth Bama
    I always thought anything over 2" on the rear on the 04-08's required a flip kit, and lift shackles. Yes, I said lift shackles. :jester:
  9. Predatory Instincts
    Burger King's bathroom
    Just go old skool and take a torch to it.
  10. 07Fx2
    Oklahoma
    Lmao the kit is a flip kit. Did I forget to mention that? :jester:
