Mh1 fog light retrofit guide
Discussion in 'General Discussions' started by 2thousand5four, Dec 23, 2015.
  1. 2thousand5four
    2thousand5four Full Access Member
    Virginia
    Yep it's all ran under the carpet. That could be the issue but I doubt it since I didn't have static when I had my led fogs installed with the same wiring. But I'll double check everything. Cause that could be the case
    Twisted pair on audio to amp rca cables
    8 inch minimum separation between power and audio cables and if ya do have to run them by each other do it at a 90 degree intersection.
    Still think the ferrous load will solve the noise issue.
  3. 2thousand5four
    Virginia
    I think it's a combination of a bad ground and not having the ferrous rings. I moved the ground to a different bolt and that helped a lot. Since I have both efans powered and grounded to the battery I kinda didn't wanna ground the lights there just to make it look a little cleaner. So I think I'm gonna add a fuse box with a common ground under the hood that way I know there is a good ground and everything will be clean.
