i disagree ...... the black truck has a 6" fabtech and 35" bfg's ....... ive also parked it beside my buddys red scab f150 with a 5" RCX and 35s and it was bigger than his ......
Ur truck does not sit higher than that red one with the rcx or higher than screwgreens's. There is alotttt more clearance with a rcx. Just cuz u jammed some big fawkfawkfawkfawkin tires on not enough lift and that raised it a little doesn't mean a 3" body gives u more lift than a 5" SUSPENSION lift u jackass lol
Ah for starters your tires are taller....second if you max the T bars out on a 6" RCX it WILL be taller sfb....Your stuff is maxed out...most lift kits are not but can be...just ask twin nn
it dont matter how much clearance you got...... you could have a 20" suspension , but unless you got big tires it dont matter ..... yer differentials are gonna hang before the frame jackass!!!!
