Mpg gain?
Discussion in 'General Discussions' started by Sl33p3r, Jul 2, 2011.
  1. TFIDDLE
    If u get better mpg towing, ur tune is off. Its givin it to much gas I suspect and therefore there is a happy medium wen towing because it works harder but idk
  2. HammerDown
    HammerDown Pin It To Win It
    Western NY
    make sure your in the right gear too :jester:
    jk...I hope
  3. TFIDDLE
    Turn overdrive on!
  4. HammerDown
    Western NY
    even that I've gotten 12ish when my coil pack went bad and I took overdrive off
  5. Bdons-SD
    Air resistance!? Thats your honest excuse for 33s in the back? Air flow? You are truly an ignoramus Wtf!? I meant the way it looks.... Big tires in the rear and small up front like a funny car you nit wit. Not the tire tread. I didn't reference tread once. The sheer size of a 33 vs a 31 is huge! It looks like shat for one. Just because you can clear 33s in the rear doesn't mean you should. Level the damn thing and match up your tires. You don't need 33s to tow, just good tread. I maintain tractors, trucks and our cars, I know a thing or 2, and judging by your idiotic attempts at arguing you have absolutely no idea what you are doing.
  6. Predatory Instincts
    Burger King's bathroom
    Wait a minute..
    You think adding headers, deleting cats and welding on a glasspack is going to give you more backpressure than running factory cats with no muffler... and having 33's on the rear with 31's on the front gives you some sort of added aerodynamic efficiency. Did I read that correctly?
    What viscosity is the tractor oil that you are using anyway?
  7. Bdons-SD
    Don't even try man, this kid deserves the mileage he's getting. I know I'm only a few years older than him, but it's quite clear to me that I have more mechanical intelligence in my pinky finger than his whole inbred brain does.
  8. Bdons-SD
    I'm pro ban on this numb skull. I hate for stupidity to clog up our little slice o' heaven
  9. Bdons-SD
    I know youre on the right side here, but even if the tractor oil was a thinner viscosity it's still bad for a gas motor just due to the additives in the oil to accommodate the diesel motor.
  10. Predatory Instincts
    True.. just not quite as bad as all of the additives plus the consistency of corn syrup.
