My 1996 F150 fixer-upper!
Discussion in 'General Discussions' started by Pity7700, May 29, 2016.
  1. Pity7700
    That's not good! For $50 it better work.
    Sent from my LGLS990 using Tapatalk
  2. Bdons-SD
    I've always read good things about them. Maybe mine was just bad luck.
    Pity7700 likes this.
  3. Pity7700
    Got it on, didn't fix the issue but the old coil tip was loose so it was probably needing a new one soon anyways. The rest of the ignition system is new so why not replace it?
    Time to dig around again.
  4. ak_cowboy
    Going to be like a new truck soon! What kind of mpg are you getting?
  5. Pity7700
    Mileage is shitty. Haven't driven it much before replacing the PCM .
    I think he truck just died though.
    Seafoamed the engine, thing won't start. Thought maybe I hydrolocked it, pulled the plugs and blew the cylinders out. My buddy came over to give me a hand. He noticed that the fuel pump wasn't cycling when the key was turned to the on position.
    Got the plugs and wires put back in/on and got the truck to run off starting fluid. Doesn't seem to be getting fuel now.
    I don't know wtf is going on lol. I'll check it out tomorrow!
  6. Bdons-SD
    Talk about 2 steps forward 1 step back
  7. Pity7700
    yea no shit lol im ticked. wanted to try to clean the engine out with some seafoam and now it dont work at all.
    kinda odd. checked the fuel shutoff switch at the passenger kick panel, its not tripped. checked the relay and switched it with the horn relay, it works.
    some thing odd, fuse doesnt have 12volts across it when the key is turned to the ON position. that aint right.
  8. Roush PSD Interceptor
    Dang it man.
  9. Bdons-SD
    Dang... Every test I can think of, you already did ha ha. What did you get yourself into?
  10. Pity7700
    I'm an idiot.
    While I was letting the seafoam sit, I pulled the dash cluster out to replace the CEL bulb. In order to pull the dash trim off you have to unplug the fuel tank selector switch.
    I didn't plug it back in....even though I only have 1 tank, the plug still needs to be plugged in to complete the circuit.
    Truck runs.
    Let's forget this happened.
    On to the P0385 (crank sensor code).
    I did just retrieve an EGR insufficient flow code as well. Getting ready to test the DPFE before I start replacing more crap.
