My 1996 F150 fixer-upper!
Discussion in 'General Discussions' started by Pity7700, May 29, 2016.
  1. thesman727
    thesman727 Full Access Member
    US
    Slow clap
    Pity7700 likes this.
  2. Pity7700
    Hahaha I said, leta forget about it!
    Sent from my LGLS990 using Tapatalk
  3. ak_cowboy
    bwhaha at least you have one problem fixed
  4. Pity7700
    Hahaha yea.
    Need to figure out this crank sensor issue. I'm sure whatever it is, it has to do with why the exhaust is smoking.
  5. Pity7700
    Alright messed around with the truck for a bit today.
    Got myself some new hoses for the DPFE, they were pretty rough.
    I did have a P0401 code pop up today, EGR insufficient flow. I've had this pop up in the past a time or two.
    Tried replacing the DPFE and then the EGR, no luck. Still rough idle. Thought maybe one of the two was causing my issues. Hoping something was sucking. not the case, both parts are being returned, getting frustrated.
    I will say, I drove 2 miles without the CEL coming on. Once I got up to 35+ mph, that crank sensor code popped up.
  6. Roush PSD Interceptor
    Did you try the distributor electrical
    part yet?
  7. Pity7700
    No I have not.
    From what I've been reading, if the sensor inside the distributor was bad, the truck wouldn't even start.
    The truck starts and runs with a slight stumble at idle, runs fine when Im on the gas.
  8. Roush PSD Interceptor
    Maybe time to smoke test for a vacuum leak?
  9. Pity7700
    That's what I want to do. I don't think I can rent a smoke testing unit out, that's how I remember doing it in school.
  10. Roush PSD Interceptor
    Check out the first YouTube video
    "Checking for vacuum leaks
    using home made smoke pump"
    Instead of the nebulizer pump an aquarium
    air pump will work.
    If ya can't find a used one new are $12 @ Walmart.
