My 1996 F150 fixer-upper!
Discussion in 'General Discussions' started by Pity7700, May 29, 2016.
  1. Pity7700
    Thanks Joe!
    I might just jump ahead and replace all of the vac lines in the truck. I've replaced a few vac lines and some coolant lines already.
  2. Bdons-SD
    There's still that misfire sensor too, could be worth looking at.
    Pity7700 likes this.
  3. Pity7700
    That's the sensor I'm working with, the sensor is brand new.
    I'll run tests on it again just to be sure there are no open wires in the circuit.
  4. Pity7700
    That home made smoke pump is pretty sweet. I might just do that anyways.
  5. Roush PSD Interceptor
    I've seen a D battery powered air pump called
    "Quiet Bubbles" in the fishing supplies of Walmart
    for around $10.
    So about the same cost as the
    110 volt aquaruim pump vs buying D cell batteries.
  6. Bdons-SD
    Ah, ok, I wasn't sure if you had a new or not, this thread is long ha ha.
  7. Pity7700
    Made a smoke can!
    2 fittings with a rubber sticker around it so air doesn't come out around the fittings. Got those from work, they come in handy. I also put a shutoff valve on the can, decided to use my air compressor and just turn the pressure down to around 5psi. It works pretty good, tried it out with some burning leaves inside. They burn to quick to keep steady flow of smoke though.
    Heading to the gas station to get a cigar.
  8. Roush PSD Interceptor
    Awesome
    No extra air pump needed !
  9. Pity7700
    Now I smell like a black and mild.
    The homemade smoke can works pretty good. Smoked the system but the only smoke that came out was through the throttle body. I gotta get some rubber gloves to throw around the throttle body openings, tried using a plastic bag but I couldn't get it to seal tight enough.
  10. Roush PSD Interceptor
    Wrap a rubber band around the bag.
