Alright. Ill start looking at some parts and post up links to see what you think will work good together. I'm hoping I can get my block to the machine shop tomorrow so it'll be done next week sometime. Im getting kind of antsy with all these parts just chillin in my garage lol
Just talked to another shop... $100 to bore it $50 for new freeze plugs $40 to clean it $200ish to balance the crank with aftermarket pistons/rods Not a bad price in my opinion, but I need to order my pistons, bearings, etc before I can have anything done. Ill basically connect rods with pistons and then take everything up to him. When he balances the crank will he install everything inside the block? I'm not sure how that works...
Well to balance the rotating assembly they'll take the pistons bob weight em, dynamic balance the setup and then install into the block
In all honesty if you haven't ever messed with wrist pins before just have them put the pistons on the rods, it won't cost much
Never done wrist pins before. When I get home from the gym I'm gonna call around and see what I can get. Piston heads w/ rings Wrist pins Main bearings Rod bearings Anything else ill need to get this machine work started?
Usually a shop will carry all the bearing and rings you'll need an they all have certain types each prefer so they should have those for you. Biggest thing is you'll need to bring them pistons or have them order some, sometimes they can get you a better deal than you can, so that they can bore an hone match the cylinders to the pistons. You should be able to use old wrist pins
Can't thank you enough for all the help you're giving me Danny. Its a CarQuest so I'm sure they do have parts or can order them in. Ill have to go up and talk to him next week, I just got called into work in 10 min
No worries man. Car quest engine shop? Not trying to rag on them but make sure you feel like they're competent before you give them your stuff
Yeah I got referres to them from my buddys shop. Said the guys been doin it for 30 years or something, still have to talk to him so nothings final yet.
