My 5.4 Build
Discussion in 'Engine & Performance' started by MyFX4Project, Aug 18, 2013.
  1. Pity7700
    yall got me wanting to buy a trashed block.
    cant wait to see the work on this thing dude.
  2. MyFX4Project
    MyFX4Project TRUCKIT
    Kansas
    Making it mandatory for me to stop by the shop in the morning and get this engine stuff figured out. Hopefully they know a little something about these modular engines to help me decide on piston dish, cam size, etc. Thats all I'm really stuck on.
    I read that Mahle 16cc dished pistons will yield a 8.99:1 CR while their flat tops will make 10.82:1.
    $559.22 for a set of 8 with pins, rings, and locks.
    Comp cams stage 1: 226/230 @.050 .550 lift. Valve springs recommended and PTV clearance needs to be checked.
    Seema as though a spring upgrade and TC upgrade are in store if I go with stage 2 cams with a higher lift and I'm not sure if I want to do springs... haven't decided.
    Ill be back with more info tomorrow after talking to machine shop!!! :D
  3. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    That that much duration that's gonna be one choppy ass idle..
    What's power goals?
    Sent from my iPhone 4 using Ford Power
  4. MyFX4Project
    Kansas
    I'd like to hit 300hp. The more the better but I'm pretty much sticking with new pistons, cams, and possibly springs depending on the cam. Stock crank and rods. Heads have been ported and resurfaced and block will be re honed and bored .020 over.
  5. AKBray907
    Those mahle pistons would be for dropping the cr if you were running big boost, the flattops would help make some power but youd need premium fuel. 226/230 isn't that much duration, it's really pretty mild, what's the lobe seperation on those cams?
  6. MyFX4Project
    Kansas
    I'd have to double check the website tomorrow, I'm at work right now. They are comp cams stage 1 for 5.4 you can find em pretty easily on MMR.com.
  7. MyFX4Project
    Kansas
  8. MyFX4Project
    Kansas
    Lobe separation: 113º
    Well the freakin machinist didn't come in until 9 and I wasn't about to wait an hour to see him. :mad:Might head up a little later today after I catch some sleep.
    Or
    Stage 2 comp cams:
    270in/274 ex
    Lift .550/.550
    Lobe separation:113º
    Requires valve springs
  9. AKBray907
    Bummer man, that's quite a step from stage 1-2 as far as duration goes, ill do some looking later an see if I can find any other cam options
  10. MyFX4Project
    Kansas
    Yeah that's what I was thinking too. Dont even get me started on stage 3... :jester:
