My AC Issues
Discussion in 'General Discussions' started by VanoFord, Jun 26, 2012.
  1. UtahFord
    Good thing haynes covers everything
    sent from my badass F-350
  2. VanoFord
    I got a few questions for anyone that knows AC systems well. Hooked my gauges up and I read 110 on low side and 125 on high side. This is while the truck is off.
    If they both equal then this high of a static charge, then my system does not have a leak correct? Could my compressor br bad and that's why I have no cold air?
  3. VanoFord
    Now I'm runnin the truck w/ a 1500rpm idle. My low reads 0 and my high reads 125. The air out the vent is slightly cooler than ambient temp. Sounds like I'm just a can of r134 low. I must have had problems cause I would try to fill while the truck was idlig at 700. Any thoughts to all of this guys? Thanks in advance
    Just shut the truck off. The low side is slowly goin back to 110. Is it a bad compressor? Ugh. I'm melting in Texas and would love any assistance. Thanks!
  4. Eric of Memphis
    munford tn
    ok its better to tell ya to do this cuz there could be something else wrong /......... quit being cheap and take it to a shop .... on these 134 systems there is alot of if and what if etc..... it could be an orfice tube it could be this it could be that........ im not trying to be rude but there is alot to ones like we have
  5. Eric of Memphis
    munford tn
    and if low side is at 0 and high side is at 300 that = bad granted it might cost ya 300- 1000 dollars to fix it correctly i just spent 600 on my truck and i get parts at cost and do mine myself
  6. VanoFord
    I appreciate the warning. Truth be told I don't have the cash to pay a shop to fix it. I have money for me to attempt the fix and then if not I'll jus suck it up for the remainder of the summer.
    Roushpsd mentioned an evaporator valve in the dryer typically goes bad. I ordered and have a new dryer. So I'll swap out that and recharge Nd go from there. Thanks again. I appreciate the warning but I can't afford an AC cost right now other than what I've currently spent.
  7. Roush PSD Interceptor
    Saw the expansion valve online for $1.35 Vano.
    The pain of "EPA evacuation", changing the dryer, pulling a vacuum
    and recharging the system.
  8. Eric of Memphis
    munford tn
    Our trucks have orifice tubes you will need a tool to remove it it's always a good idea to replace the accumulator / drier when you open the system up and also if you don't pull a vacuum on the system and it needs to be a 40 to 50 min vacuum other wise it will not work efficiently and you will still burn up
  9. VanoFord
    I took the dryer/acc out to the truck and t looks like its the wrong one. I'm gonna take t to a local shop and see what they say.
    Psd can you post a link of that expansion valve please?Thanks
  10. Roush PSD Interceptor
