Ok I have tried everything except o2's. I have p0171 and p0174 bank 1 & 2 lean codes. What should I replace. I also need brake pads if anyone has a how to with pics. Sent from my bad ass phone
Brake pads are super easy. Support vehicle Remove tires 2 12 mm bolts hold caliper Swap pads Compress caliper Reinstall caliper and wheel I had those lean codes and had to replace fuel pump
Brakes are maybe a 45 min job. The hard part is figuring out which ones to get. There like 7 different types of pads for the front of our trucks.
I had the left and right bank lean codes and I just pushed on a loose vacuum elbow on the intake manifold and they went away immediately. --- I am here: http://maps.google.com/maps?ll=38.863205,-76.848165
Thanks Dan, for joining up to the forum to help a member. Welcome to the site, you should make an intro thread
It's not driving like it has a bad pump. It drives normal doesn't bog up hill it just slows down like normal goin up a hill. Maybe a fuel filter but do I need to pour gas in the new filter or will the pump do all the work? Sent from my bad ass phone
I did that to the PVC valve elbow and I got up to 223 miles ( gotta have 250 after replacing a batt or clearing codes for emissions) I was pissed I thought it was fixed. I'm gonna pull the o2's n see what they look like. Sent from my bad ass phone
Pump will do the work. Do what u want but I had the codes and a pump fixed mine. Yours may be a different issue. I'm sure some kid working behind a counter doesn't know shat about a vehicle unless is a Honda
