my soon-to-be 97 Explorer
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by Ninjawafers, Jan 25, 2011.
  1. Ninjawafers
    Ninjawafers Full Access Member
    Key West
    found it on the interwebs... looks like ill be able to run 31x10.50x15's being completely stock
    95-2001 (including 2dr 95 - present)
    No lift- 31x10.50x15 on 15x8 rim or stock (15x7) rim
    1-2 inch suspension lift - 32x11.50x15 on 15x8 rim/ may require some extensive fender trimming
    4 inch suspension – 33x12.50x15 on 15x8 rim
    2 inch body lift – 32x11.50x15 on 15x8 rim
    3 inch body lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
    2 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
    2 inch body lift and 4 inch suspension lift - 33x12.50x15 – 35x12.50x15 on 15x8 rim/ may require fender trimming
    3 inch body lift and 1-2 inch suspension lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
    3 inch body lift and 4 inch suspension lift – 33x12.50x15 – 35.12.50x15 on 15x8 rim/ may require fender trimming.
    You may be able to run 33x10.50x15s inplace of 32x11.50x15s
  2. ADTR288
    ADTR288 Full Access Member
    Phoenix, Az
    thats exactly what i had for my first vehicle, there awesome, i would say bedlin the bumpers black black steelies with some all-terrains, tube front bumper with some lights and crank the t-bars.
  3. liter of cola
    liter of cola X tra L arge
    INDIANA
    sweet dude you cant go wrong with a free vehicle! even if it needs a little work! fix it, drive it, then sell it and make some scrilla!
  4. Ninjawafers
    Key West
    ill be keeping this one for a while. it has some cosmetic things and interior things i need to fix, and that will be taken care of, and all the chrome will disappear. the truck will be a blue/black scheme, just not sure how far into a project i want to take this one.
  5. ksingltn
    ksingltn Full Access Member
    Anniston, AL
    make sure your tires are evenly worn. Even a little difference front and rear you will be shopping for a new transfer case before too long. The AWD models are very sensitive to this. Regular rotation is key.
    So the problem was simply a loose nut between the steering wheel and the headrest?
  6. Ninjawafers
    Key West
    lol yeah... when you engage the brakes, the pedal stays in the down position and the brakes stay engaged... they dont release unless you physically pull the brake pedal back up... the rest of the issues is just replacing some worn and broken odds and ends
  7. Ninjawafers
    Key West
    just ordered some new driver's side front and rear door handles and some new universal 3 point seat belts for the rear... the seat belts will be a chore to install, but it will be worth it. having a welder father-in-law and a mechanic brother-in-law that live maybe 15 minutes away always helps too :)
  8. Ninjawafers
    Key West
    anyone got any ideas where i can get a tubular front bumper? ive googled around and have only found a rear
