Need Some Exhaust Help!
Discussion in 'Engine & Performance' started by Bee89, Jan 23, 2012.
  1. Bee89
    Bee89 Super Moderator
    Miami, Florida
    I think i honestly just dont produce enough force to get them lose. Im going to try again with a breaker bar and see what happens before i resort to cutting it off.
    good luck :superhack:
  3. Bee89
    Miami, Florida
    Thanks Will !
  4. TxFx04
    spray a good amount of WD-40 or some sort of oil in the clamp, loosen it all the way, get a screw driver to pry in between the clamp and the pipe and see if that works
  5. iowaredneck
    yup, soak them suckers for a few hours before trying to loosen them, that should help
  6. VanoFord
    if you have a 5lb hand sledge, combined w/ a breaker bar, it should come right off. now, if it doesnt, cut the pipe work off just in front of that factory clamp and you can get another exhaust clamp from VatoZone.
  7. ak_cowboy
    fugg wd-40. You need some PB Blaster :peace: Its a penetrating oil that will actually work through the rust, WD-40 is just a water deterrence.... its not even that great of a lubricant...
  8. Bee89
    Miami, Florida
    ^^ thats exactly what i have at home. Its the only stuff i use :)
  9. TxFx04
    i think bee just needs a little more muscle to take that there muffler off
  10. str8t six
    str8t six never enough
    Back in VA
    loosen the clamp and just tie your muffler to a palm tree and drive forward to pull it undone!
    what could go wrong? :jester:
