need to find out if it is a motor mount first! I doubt its under warranty lol I rolled under the truck and checked the motor mounts, they looked ok, bushings seemed like they were in place. there are only 3 fords at my parents house. my dads truck, the work pick up and then mine.
I dont think its a motor mount. I just bought two brand new ones for my engine and they look nothing like that. Ill get pics tomorrorw.
I've run into those Ford doesn't know what it is part #'s before. Hope it's from another vehicle and not from your 7700.
it might not have anything to do with mine lol im just making sure since I am having an issue right now. thought maybe something is missing its mount causing it to move while im driving but it seems like everything is in order.
for the hell of it I flipped the yoke at the trans side of the shaft...just trying anything I can. this time when I took the shaft off of the rear diff I noticed some fluid coming out, wasn't enough to drip on the driveway though. normal?
If you got fluid coming out of the rear diff its probably a pinion seal. Fluidn coming out of transfer case/tranny is normal.
yea I only noticed it when I took the driveshaft off, I don't see anything dripping. I just wonder if whatever is going wrong is causing the seal to start leaking now.
well I took the shaft off and spun the yoke around, seems like the sound quieted down quite a bit. the yoke was perfectly aligned with my alignment mark from when I put my u joints in. so now my alignment marks on the drive shaft and the yoke are complete opposite. making me think about doing the same at the rear end.
