Need Some Help
Discussion in 'Lifted' started by HammerDown, Apr 22, 2011.
  1. HammerDown
    HammerDown Pin It To Win It
    Western NY
    with the addition of the new add a leafs, I also too out the wedge piece that sits with the axle block (needed for lowering shackles but wanted to try it without)
    So what I need help with is the pinion angle for the rear axle and drive shaft
  2. Darth Bama
    Are you wanting to know what the factory pinion angle is?
    Anything over 2" supposedly requires shims. Although I'm a lot lower then 2" in the rear and have never had any vibration. So I would assume if you're lifting it's the same as lowering. Anything over 2" probably requires the shims. :think:
  3. HammerDown
    Western NY
    it has lowering shackles and hangers, but also AAL so yes I need the factory angle
  4. Darth Bama
    You're planning on taking the drop shackles out aren't ya???
  5. HammerDown
    Western NY
    eventually but not right now
  6. Darth Bama
    Unless you're getting some driveline vibration, I wouldn't worry about it to be honest dude.
  7. iowaredneck
    ^x2
  8. HammerDown
    Western NY
    I am getting some vibration at lower speeds though...right now the differential is pointed up slightly more than the axle is
  9. iowaredneck
    need shims then
  10. HammerDown
    Western NY
    I have them but the head of the pin isn't long enough to go through the shim and to the block so I was just trying to figure out the right angle so I can try other things too
    EDIT...all worked out thanks anyways
