Need to move the truck but doesn't shift.
Discussion in 'General Discussions' started by cowboy, Apr 27, 2016.
  1. cowboy
    OK so my truck has been sitting forever now. It will fire right up but won't shift into gear. Fluids look fine. Thinking about dropping the drive shaft to move it out of the backyard so I can get it towed. Question is do I need to drop both shafts or just the one to the rear tires?
    Think you're ok if it shifts to neutral.
    You'll know when you start to pull, it
    will either free roll or be a bear to move.
    If ya have to drop the shaft, be sure to mark it
    for reinstall.
  3. cowboy
    Will do. Yeah I left it in park. Don't think I can get it shifted to neutral.
    Sent from my Nexus 6P using Tapatalk
  4. Bdons-SD
    Neutral safety switch maybe?
  5. cowboy
    Neutral safety switch? What's that and where?
  6. Roush PSD Interceptor
    Have you tried removing the gear selector lever from the transmission and shift it by hand at the transmission?
    Chock them wheels first.
  7. ak_cowboy
    There should be a manual release button by the shifter, check the manual.
  8. Bdons-SD
    It prevents the truck from being shifted out of park if the brake isn't pushed down or the key isn't switched to run, it's usually on the side of the transmission. Is the gear selector not moving at all? Like it's stuck? Or is it the transmission that's not shifting into gear when you move the gear selector?
    X2 what will said. There should be a way to override the neutral safety switch/ ignition cylinder to move the gear selector.
  9. cowboy
    I can move the shifter, but the transmission isn't shifting.
  10. Bdons-SD
    Ah. Ok, yeah, forget everything I said then.
    Edit: i meant forget, not first ha ha
