Need to stop the annoying sounds!!
Discussion in 'General Discussions' started by lovemyfx4, Apr 3, 2011.
  1. lovemyfx4
    lovemyfx4 Full Access Member
    elburn il
    Ok the truck's drivin me crazy. :Grenade:Something in the driver's front corner, suspension wise, is sqeeking. It makes the noise on every bump. What could be the cause of this? Any ideas welcomed. Also the top half of my sway bar end link on the passenger side has disconnected itself, do i have to go buy a new end link or just a bolt to fix it?
  2. supercrewzn
    ball joints are squeeking. Id replace both end links. They are cheap parts.
  3. rrogers
    squeeky ball joints
  4. TxFx04
    just buy new end link bushings and bolts. it's a $20 and if it squeaks when you hit a bump it's most likely your balljoints going out. I had the same problem, every little bump it would squeak like crazy. Time to replace your uppers A arms and lower balljoints, make sure to get the ones with grease fittings on them.
  5. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    does your truck look lower in the front? does it do it when you turn? if not then it isnt ball joints
    if its bumps only it its your shocks my rear shocks are annoying as hell
  6. THEPRODJECT01
    THEPRODJECT01 MARKK
    odum , ga
    i hope you can work on trucks, cause a tire shop will rip you a new one to put ball joints on, parts are less then 70 bucks and if you can put them on your self, thats all you would have tied up in it, you would have to rent a ball joint puller
  7. iowaredneck
    ball joints dood
  8. TFIDDLE
    Ball joints and they take forever to put on without a tool
  9. THEPRODJECT01
    THEPRODJECT01 MARKK
    odum , ga
    yea, you can rent a special tool for it at o'reilys
  10. swamphunter
    swamphunter Full Access Member
    greeneville tn
    Easy to put on without special tool put ball joint in hole with nut on thread put bottle jack under it jack it up tell it's pushing on the bolt and wack the a arm with a hammer then jack it up lil more and wack some more and b4 u know it it's on
