Going to get some more pics. Getting exterior parts so truck may look different Sent from my LG-V410 using Tapatalk
Alright. Got a like new tail gate, new rear bumper, bed liner AMD a replacement radiator. No luck on replacement bed itself. But it seems its looking like I'm going to have to fix the bed myself. Sent from my LG-V410 using Tapatalk
Look to the right on this Amazon page for cheaper options. Black $65.97 free shipping from East Coast Jeeps https://www.amazon.com/dp/B000CN99FW/ref=psdc_15731711_t1_B000CNB1L2 Red $75.67 free shipping from TRU Motorsports https://www.amazon.com/Energy-Suspe...coding=UTF8&psc=1&refRID=8FTQGG5QTHQZEP1BJF1R @jdogali1989
Alright folks, Next on the list is she's going to need a rebuild on the front have a good amount of play in the steering. Question is what will i need? Sent from my LG-V410 using Tapatalk
Howd the body / bed mounts go? Could be steering box, drag link, tie rod ends, loose steering column u-joint. Depends where you find the suspect part in simple end play testing. Jacking safety a must when checking any front end components, jack stands and wheel chocks. Pry bar and eyes and ears looking and checking how much movement is ok and how much is not ok in a part. Sent from my SM-G930P using Tapatalk
Are there zerk fittings on the joints? Are the dust boots intact? When / is there evidence of last time it was greased / serviced? Many questions on a used vehicle. Sent from my SM-G930P using Tapatalk
Check up and down and left, top to bottom and right end play on each safely lift / jacked front tire. You're looking for excessive movement. Sent from my SM-G930P using Tapatalk
Could be wheel bearing or ball joint movement even worn tie rod ends causing excessive movement at wheels. Sent from my SM-G930P using Tapatalk
